Ir para o conteúdo principal
A série Signet foi a linha de câmeras de 35 mm da Kodak de fabricação americana mais sofisticada na década de 1950. É um dos apenas dois modelos Signet que contém um telêmetro, e o único que não é feito principalmente de plástico.
double superimposed rangefinder patches problem
When view through viewfinder on kodak signet 35 , the rangefinder patch appear from 2 triangle 70% superimposed but slightly shifted horizontally on left side.I could not discern what would cause one triangle to split into two, though I suspect it's a a misalignment. What area should I be inspecting?.I wait for yours ideas.Thanks.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Your beamsplitter got mis-aligned. Review this IFIXIT guide: Substituição do divisor de feixe da Kodak Signet 35. There should be a couple of small setscrews which has some glue on in to prevent it from shifting. One is to adjust the parallax (up & down) the other the infinity set.
Esta resposta foi útil?
Pontuação 3
3 comentários:
where could I buy a new one beam splitter ,because the coating of beam splitter does not exist and when view through viewfinder the triangle from the rangefinder is not longer visible , and i try using a piece of blank 35mm color negative that has been processed which I put behind the beam splitter, and followed these procedures the triangle of beam splitter is visible , but appears as double triangle, probable first triangle is a reflection of 35mm colour negative film procesed , and the second triangle is reflection of beamsplitter glass.What do you think.Thanks
por Compartilhar
This is such an old camera parts will be difficult to find. Maybe you can find a second non-working camera to steal the part from to fix yours.
por Compartilhar
Thank you very much
por Compartilhar
Adicionar a sua resposta
Florentin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 36
Ao todo: 848
