Ir para o conteúdo principal
Um monitor LCD de 17" para computadores Apple produzido entre 2001 e 2004.
Studio Display has gone black.
Power's getting to my M7649 Display, from my G5, but the screen went black a few days ago. I got another M7649 display from a friend and it works fine. Can mine be fixed? is it the inverter? Screen seems black, not dim.
Thanks,
Henry
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
If you look closely at the display (maybe at an angle) you may be able to see a slight image (like a shadow) if so your backlight has failed and would need replacement.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks Wizbang FL! Appreciated.
I plugged it back into the G5, turned off all the lights in the room, fired up the computer and looked for a glimmer of an image, or shadow. Nada. Ziltch. Pure darkness ... except for the 'on' light in the lower right corner of the frame, of course. Holding the screen brightness button brought the button to life, while it was pressed, but nothing more.
So ... I'm now certain that the display is imageless.
Still looking to allow this display to play as it has. If there's a fix, and it won't cost me an arm or leg for the part(s), I'll try it.
Regards,
Henry
por Compartilhar
Pergunta mais útil
Before replacing the backlight, you might want to take a look at the inverter that controls the backlight. Here's the Apple recall on it and how to fix it: http://macguild.org/display-repair.html
Here's the guide on repairing it from iFixit: Substituição do inversor do Apple Studio Display M7649
Pontuação 3
Adicionar a sua resposta
Henry será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 31
Ao todo: 1,799
