Uneven bands and the ear cup is st the wrong angle.
My headset band is uneven as in one side is longer than the other.
Esta é uma boa pergunta?
Haly “Haly” not sure what you mean the headband is longer on one side. You can adjust the aluminum arms on either side (part where teh driver (speaker) is mounted to. That should even this out. If there is anything else going on with it, post some images of it with your question. Use this guide Adicionar imagens a uma pergunta já existente for that so we can see what you see.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 189
1 comentário
I have this same problem too. Basically one side of the headband is longer than the other and the 2 earcups are not aligned together. (One ear cup is higher than the other.) I've checked the whole headset and I can't find what's wrong with it.
por Vincent Adeola
