Ir para o conteúdo principal
How to take apart and repair the Panasonic Lumix DMC-FX01.
12 Perguntas Visualizar todos
My camera fell in water
Hi,
First of all, I'm sorry about my bad English, I speak Portuguese.
My Camera fell in water, while i was taking pictures with my friends, and stopped working immediately, i would like to know if is there any hope!
I love this camera please help me!
Thank you!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Kubillas, first off when did this happen? Recently? Remove the battery and do place the whole camera in a bag of uncooked rice for a couple of days to dry out. Do not turn it on. There is always hope for as long as you let it dry thouroughly first and do not try to turn it on. I placed the service manual for to your camera on my file server and this should help to disassemble your camera and to clean the main board with isopropyl alcohol and to check for any debris and damage. After it has dried out and is clean of corrosion and debris, reassemble it and place a new battery before trying to restart. Good Luck.
Esta resposta foi útil?
Pontuação 3
1 comentário:
It happens last month, and i left it disassembled since then.
Thanks for the answer, now let me try to Fix it, and I'll let you know what happened.
por
Adicionar a sua resposta
Kubillas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 1,768
