The console refuse to read a disc
My PS2 has been used for 7 years and recently it doesn't read any disc but the browser said "Reading disc...".After a few minutes it said "Disc read error".Any solutions?
Esta é uma boa pergunta?
I am assuming that you are out of warranty since your console has been used for 7 years :-) Of course you may just have a dirty laser that needs to be cleaning and most recommend isopropyl alcohol or just a good optical lens cleaning cloth, available in most department stores with their spectacles. The other issue could of course be mechanical in nature that need a little bit more effort. There is a great guide right here it is also possible that you will require a new laser assmbly if your laser should not be working at all. PlayStation 2 Optical Disc Drive Laser Assembly Replacement has that. There are also decent instruction in how to deal with your read error drive right here and some more here. Good Luck to you and see if it works for you.
Guia
Nível de dificuldade:
Fácil
15 - 40 minutes
Guia
Moderada
20 minutes
Esta resposta foi útil?
welli have a Ps2 slim and its reading some discs but some not what to do???
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,260
5 comentários
I've tried to clean the lens.But it is not working.
por Honam1021
My device model is SCPH-30006
por Honam1021
Have you checked on the links that talk about the adjustment? I believe its the last one I posted in my answer.
por oldturkey03
I checked the links,but they doesn't work for me.
por Honam1021
If even after adjustments and cleaning and after making sure that your dives cables are all connected appropriately I think you may just be due for a new drive :( sorry
por oldturkey03
