Ir para o conteúdo principal
O Sentra finalmente entrou na categoria "compacto" quando o modelo redesenhado foi lançado no final de 1999 como um modelo do ano 2000.
RPM Drops to Zero while Driving
RPM Drops to Zero while Driving, releasing X-pedal and car slows down and RPM needle drops to Zero and car starts to Shake/Vibrate.
cleaned throttle body, air flow sensor, changed coil packs, no engine light comes on, changed speed sensor because of misfiring (not changing to 2nd gear).
Didnt service injectors yet, its a bit expensive .
please help me!!
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
I own such a car and model This malfunction is for the tps sensor and needs to be re-calibrated and the number is set on the computer number 48 for the automatic car and the number 46 for the vehicle The symptoms of this malfunction are what I mentioned in your question in addition to the violent switching of the gearbox there is a solution to re-calibrate and another solution is the work of Rest For the car computerIt is a temporary and effective solution, and the way to put the key and manage the car key without operating once the Airbag indicator has disappeared. Close the key as soon as you hear a computer click.Repeat the step again - then the third time turn the car engine - now the car computer has been restedطريقة عمل ريست لكمبيوتر السيارة نيسان صني n16
Esta resposta foi útil?
Pontuação 0
Une moteur
Il me taire
Pontuação 0
1 comentário:
Huile moteur
por
Adicionar a sua resposta
Nex Gen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 4,510
