Ir para o conteúdo principal
The current line of iPod touch comprises seven (7) different generations.
How to replace the charging port on iPod touch
How do I replace the charging port on an ipod touch? The cord was accidentally yanked out and broke a couple prongs inside the ipod. So it will no longer charge or connect to PC.
Esta é uma boa pergunta?
Pontuação 21
11 comentários
Which iPod touch do you have? Depending on the generation of iPod that you have, it does make a difference.
por
I Have Exactly the same problem on a 2nd generation 8gb touch.
would love some help with this.
por
yea so it needs a replacement logic board basicly?
is it possible to use the part from a 1st gen nano?
por
I don't know I have the 4th Generations and it will only charge standing up on my I home with force. So it is very hard to get apps. I am going to look on apple.com!
por
I have the same problem with my Ipod touch 4th gen but its also in recovery mode and wont go out
por
Exibir mais 6 comentários
Adicionar um comentário
6 respostas
Pergunta mais útil
On the 2nd generation, the dock connector is solder to the board. Check on the guide iPod Touch 2nd Generation Logic Board Replacement page 5 shows the dock connector. So you have to remove the logic board and then remove the dock connector by de-soldering it as well as the 2 prongs on the side that hold it on the logic board. Not a terrible job but it does require a steady hand, good eyes (or a magnifying lamp in my case)and good tools. Good luck and let us know how it is going.
Esta resposta foi útil?
Pontuação 3
6 comentários:
I HAVE A 4th gen i accidently pulled it out the charger
and i think the inside bended
por
Just follow the steps in the original answer.
por
how do i fix the iPod charger on the iPod not the charger but the charger on the iPod
por
My answer above shows how to replace the charging port on the ipod....
por
so how do you get a replacement connector?
por
Exibir mais 1 comentário
i pod 4 charging port how to change
1.open the lcd and all screws...
2.with solidering we have to re-move the up-side points on board and battery points...........
3.then after pull the board in the frame..........
4.Then keep the safety sticker on ic and capster and dont keep the sticker on charging port........
5.give heat up to 460 degree and down side of the port
6.carefull there is on down side ic are they
7.slowly pull out
Pontuação 0
Replacing a charging port on an iPod touch 4th gen or later is a standard repair done by any cell phone shop that microsolders. You could probably attempt it as DIY, or just send your ipod out to have it done and your device will be back on the road. Remember, the Apple store does not do repair, only replace. This isn't the kind of thing that they can help you with, however it is done all day every day by reputable repair shops.
Pontuação 0
2 comentários:
thx that will help
por
Thanks a lot I've been without this I pod for about 6 months and its been really boring without it and i had to get a new one.
por
I have the same problem with my white ipod 2nd Generation touch its prongs are all broken and bent
Pontuação 0
It got rice and it and then when I took it out it is lose and I can't charge it
Pontuação 0
Yeah I got question about my ipod tuch is not turning on or charging and the the slot were the charger is dented is dented how do I fix that on my ipod tuch
Pontuação 0
Adicionar a sua resposta
dallas19692003 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 56,243
