Ir para o conteúdo principal
O Samsung Galaxy Note 4 é um smartphone celular que foi lançado em outubro de 2014. O número do modelo do Galaxy Note 4 é SM-N910, SM-N910A, SM-N910T, SM-N910V ou SM-N910R4 para variantes americanas.
What is wrong with my phone?
What does this error code mean?
Imagem
https://drive.google.com/file/d/0B2IQ9j2...
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Will not connect to my network
por
Adicionar um comentário
2 respostas
Solução escolhida
Tiarra, Thanks for posting the screen image of the boot error.
This is a well known failure of a flash memory module in the Note 4. There is another thread here on ifixit discussing this problem, and some temporary fixes like installing an app named WakeLock to prevent the CPU from sleeping when idle, and freezing the phone (without battery) then installing battery to get it to restart. I had both techinques to keep my Note4 working for a time, but the condition is terminal. The only fix is a mainboard replacement. Unfortunately, the only parts available are used boards from China which may well suffer the same problem.
Several class action lawsuits have been filed against Samsung on behalf of us Note4 owners.
For more details of the problem and history, do a search for: mmc failure Note 4
Esta resposta foi útil?
Pontuação 1
Seems like phone is in Download Mode... Just simply take out the battery and insert battery pack again and It should be working fine. if not Phone OS needs to be reinstalled.
Download Firmware from https://www.sammobile.com/firmwares/ and install Firmware.
hope this helps.
Pontuação 0
Adicionar a sua resposta
Tiarra será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 2,019
