How do I replace a fuel pump on a Ford 3000 tractor?
My fuel pump is leaking and I need to repair or replace it. How do I do this?
Esta é uma boa pergunta?
@ddavis317 straight forward for the gasoline engine
Here is the Fuel System part of the SM Ford-tractor-Fuel-System.pdf for the 1965-1975 Ford Tractor
Esta resposta foi útil?
Replacing the Fuel Pump on a Ford 3000 Tractor:
Materials Needed:
Procedure:
@jerryrodan AI generated answers need to be flagged/marked as such. You are responsible for the content of the AI regurgitated technobabble answer.
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 21
Duração total: 5,154
2 comentários
@ddavis317 any idea what year your tractor is? A serial number will help with that. Also what engine does it have? The 3000 came with either a Ford 2.6L 3-cyl gasoline or a Ford Ford 2.9L 3-cyl diesel
por oldturkey03
Hi Turkey, I am pretty sure its a 1975, it is a 3 cyl. gas. Thanks for reply
por Marty
