Ir para o conteúdo principal
Caixa de som portátil JBL Flip 4. Caixa de som Bluetooth com dois alto-falantes eletrodinâmicos e classificação à prova d'água IPX7, vencedora do prêmio CES Innovation Award de 2017.
Connect + no longer opening since iOS update
For some reason ever since the update to iOS 11.2.5, my JBL Connect + app (that previously worked fine) no longer works. It now starts on a screen that directs me to turn on the Bluetooth on my iPhone X, despite it already being turned on and paired with the speaker.
No matter which order I do things in (I’ve tried turning off Bluetooth and then starting it when the Connect + app asks for it, but it still doesn’t think I have Bluetooth turned on).
I’ve tried restarting my phone, telling it to forget the speaker(s), resetting the speakers to their factory settings etc. No dice.
The main issue I have is that I use two Flip 4’s for the stereo feature but I can’t turn that on unless I can access the app.
Can anyone help or has anyone else had problems since the iOS update??
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
If your JBL Flip 4 speaker refuses to connect to another device through Bluetooth, see the JBL Flip 4 Won’t Connect Through Bluetooth problem page for possible causes and solutions.
Try:
a) first uninstall the app
b) go to Settings --> General --> Reset Network Settings
c) completely power the phone off after it resets and reboots
d) download the app again, and try pairing blu tooth from scratch.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Sorry for taking so long to respond but your solution totally solved my problem. Thank you so much for taking the time to help out. I really very sincerely appreciate it.
por
worked for me too, thanks
por
Perfect , but restarting after reseting was for my iPhone X and charge 4 not necessary
por
Adicionar a sua resposta
Max F será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 34
Ao todo: 21,080
