Would it be a good idea to put thermal paste in an iPhone?
Just wondering if anyone knew if it was a good idea to put thermal paste in between the iPhone 6S logic board and aluminum back, so the back acts like a heat sink to reduce thermal throttling during FaceTime calls.
Esta é uma boa pergunta?
1 comentário
I don't know if you still needed an answer but here you go, just recently I Applied some Thermal Paste on my iPhone 7 Plus with 79% Battery Health it's a simple task if you know how to Remove the Screen
1. I Remove the Screen and then Unplug Battery and Screen Flexible from the Logic Board
FYI Apple Is Using a Thin Cooper Above the phone's Processor and then with some Thin Graphite.
2. I Gently Pulled the Graphite Up but don't completely Remove Them, then you should be able see The Thin Cooper then you should Applied the Thermal Paste on the Cooper just a tiny bit then spread it until you cover at least 80% of the Cooper then Gently close the Graphite again and use your finger to try to stick it back again from the edge to edge if the Graphite is secured then you add more Thermal Paste on the Graphite this time add a bit more then Spread It bit by bit until you nearly covered all the Graphite and just like that you just Applied you Thermal Paste from there you can installed back all the Metal Shield.
por Mr,No Body
