Ir para o conteúdo principal
A Volkswagen baseou o Golf Mk6 na plataforma PQ35 existente do Golf Mk5. Este veículo estreou no Salão do Automóvel de Paris de 2008.
How to fix P189C problem
My car has a P189C problem. How do I solve it?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
P189C is a problem with your transmission which can't build up enough pressure. You should check your fuses first. Unfortunately I can't tell you which fuses you have to check, but I think it was a 30A fuse. If all of them are undamaged it may be a problem with some faulty wiring, bad connections or even the whole Mechatronic Unit. But even if you find and fix the problem yourself, you still need to clear the faults from your transmission control module so it is advisable to visit an authorized service station.
Esta resposta foi útil?
Pontuação 0
My only leak oil from air vent valve
Pontuação 0
Adicionar a sua resposta
David Brian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 41
Ao todo: 14,086
