Ir para o conteúdo principal
Notebook multimídia de alta performance da Asus.
Java 8 update 151 always fails to install; Java will not uninstall.
Kaspersky repeatedly advises of "important" Java update but every update attempt in Kaspersky fails "because Chrome is running" (though Chrome is not actually open).
After closing Chrome as prompted in the Kaspersky dialog, still the update fails.
Six or more Chromes are listed in Task Manager. Attempts to End task on any of these gives an alert saying that Pocket or Kaspersky etc. is crashing, so I back out.
Every attempt to uninstall Java gives an alert telling me that something (doesn't say what) is already in the process of being installed and asking me to try again later. Always the same. Never happens.
What's going on here?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @guylemec
If you are running Kaspersky Internet Security check its' settings as it might be disabling Java by default.
Java is considered to be "unsafe" but if you do need it then update it via the Java applet (Update tab) found in Control Panel.
Alternatively uninstall it (Control Panel > Programs and Features) and if you find that you do need it because of some programs you use or websites that you visit need it then you can always download the latest version and re-install it.
Esta resposta foi útil?
Pontuação 2
3 comentários:
How would I know whether Kaspersky is disabling Java by default? Where would I verify this?
For Java, you say "uninstall it" - OP title includes "Java will not uninstall".
por Compartilhar
Hi,
Did you try it from Control Panel > programs and features as suggested?
(Type Control panel in Search area on desktop)
If still no good start computer in "safe mode" and try to uninstall it then
Don't know Kaspersky but open Kaspersky and check the settings
por Compartilhar
I am going to add -- Consider replacing Kaspersky with another anti-virus. There was evidence of this company literally creating malware to convince people to use its products.
https://www.reuters.com/article/us-kaspe...
por Compartilhar
Adicionar a sua resposta
Guy Shippobotham será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 12
Ao todo: 954
