Battery compartment is broken
The battery compartment latch is broken how can we fix it we are using a rubber band doesn't work that well
Esta é uma boa pergunta?
btr1963 the latch should be available through Fujifilm as a repair part with the repair number being CR013020299. Otherwise you'd be looking at removing the back of your camera, pulling the pin for the whole battery cover and replacing it complete. You can of course try something a bit more radical like this or replace the complete cover with something like this
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 978
1 comentário
How much is the cost to replace the complete cover?
por Laurie Lethbridge
