Ir para o conteúdo principal
An entry level Android smartphone from Tracfone released in mid 2013.
Why does my lgl39c have no sound
Why does my phone have no sound?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @longknife ,
Have you checked the sound settings in the phone?
Go to Settings > Device > Sound and check that the Sound Profile setting is not set to Silent. Also check that the Quiet Time setting has not be set for particular times.
Try starting the phone in ''safe mode'' and then check to hear if the sounds work OK. If they are working now then a downloaded app may be the cause of the problem. The trick is to find out which one.
If there is still no sound which audio speaker is not working?
The phone's receiver, loudspeaker or when a headphone is inserted or all three?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Wayne Reasons será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 211
