Ir para o conteúdo principal
Fones de ouvido intra-auriculares com isolamento de ruído e microfone ControlTalk. Fabricados pela Monster como parte da linha de fones de ouvido Beats by Dr. Dre. Lançados em 2010. Número do modelo: 0000441731.
Both sides are really quiet
So for a while only one side of my earphones worked and then after I left it for a few months both sides started working again but they are really really quiet. I mean they sound like whispering at the loudest volume. Is there any way I can fix this?
Esta é uma boa pergunta?
Pontuação 1
2 comentários:
take the ear rubber off - face the earbud down and tap the top to loosen the wax while you rub the speaker metal at the bottom with a toothbrush - it will clear the dirt and wax in the small holes - volume level should return to normal
- this is what i do with my monster clarity 102 headphones
por
Thanks I had the same issue for my 102
por
Adicionar um comentário
1 resposta
i had this problem too, what i did is i sctratched the inside of the earphone and there was like some nasty leftovers in there, just remove both earbuds and scratch inside of the earphone.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Shae será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 1,871
