Why won't my car Rev over 2000rpm
Hi I have a nissan wingroad 2005 my car won't Rev over 2000rpm the engine light is not on though any ideas on what could be the problem please??
Esta é uma boa pergunta?
@pukana could be a lot of things. Check your fuel pressure, make sure that it is adequate and perform a regular tune up (things like new spark plugs, fuel filter etc.) After that check to see if this is caused by a clogged catalytic converter. To test is you would need things like back-pressure gauge, vacuum gauge and laser thermometer etc, so you might want to consider getting it check by somebody that has those tools.
Esta resposta foi útil?
@pukana That about covers it . My guess would be a clogged cat .Would still be a good idea to see if there are any stored codes just cause the lights not on doesn't mean it hadnt thrown a code previously . Odds are the downstream O2sensor isnt working right plugged the cat with raw fuel but now that the cats plugged its not getting enough data to throw a code .
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 5,128
2 comentários
hi my nissan grand livina does not pick up fully
por Zongezile Andries Ndamase
Hi, my nissan grand livina does not pick up fully .what is the problem?
