Ir para o conteúdo principal
Guias de reparo e suporte para carros fabricados pela Nissan Motor Company Ltd.
20 Perguntas Visualizar todos
Why won't my car Rev over 2000rpm
Hi I have a nissan wingroad 2005 my car won't Rev over 2000rpm the engine light is not on though any ideas on what could be the problem please??
Esta é uma boa pergunta?
Pontuação 1
2 comentários
hi my nissan grand livina does not pick up fully
por
Hi, my nissan grand livina does not pick up fully .what is the problem?
por
Adicionar um comentário
1 resposta
Solução escolhida
@pukana could be a lot of things. Check your fuel pressure, make sure that it is adequate and perform a regular tune up (things like new spark plugs, fuel filter etc.) After that check to see if this is caused by a clogged catalytic converter. To test is you would need things like back-pressure gauge, vacuum gauge and laser thermometer etc, so you might want to consider getting it check by somebody that has those tools.
Esta resposta foi útil?
Pontuação 2
1 comentário:
@pukana That about covers it . My guess would be a clogged cat .Would still be a good idea to see if there are any stored codes just cause the lights not on doesn't mean it hadnt thrown a code previously . Odds are the downstream O2sensor isnt working right plugged the cat with raw fuel but now that the cats plugged its not getting enough data to throw a code .
por
Adicionar a sua resposta
Pukana será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 5,125
