Ir para o conteúdo principal
Quadricóptero com estabilizador de câmera pré-instalado, câmera de vídeo 4K e transmissão de vídeo sem fio.
Why doesn't my drone start?
i go through the start up process, calibrate the compass, and when I pull back on the controller levers to start the motors, blinking green lights on the drone go to red and it does not start. I have repeated the process and sometimes it does start and fly as it's supposed to but most of the time it does not.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
well I would start with what I know, batteries are full in both units ?....I think you've flown this combo before, did anything happen since your last flight, maybe a "light" crash , radio (controller) get "bumped" off the kitchen table? it doesn't take much for a pcb to break a connection just to ruin your day. Without turning screws and opening anything up (not recommended) their are only a couple things it could be, I would start with the batteries
Esta resposta foi útil?
Pontuação 1
1 comentário:
I have 3 batteries and I have the same issue with all 3 fully charged. No crashes or bumps. It did set up unused for about a year but it was fine for the first 5 or 6 flights before this issue started. I thought maybe it was the Wifi extender but I'm still experiencing the same problem after changing it.
por
Adicionar a sua resposta
Alvin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 605
