Ir para o conteúdo principal
The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
13 Perguntas Visualizar todos
SW5-012 motherboard getting hot when I connect the battery
motherboard for SW5-012
I cannot power on my SW5-012 because my SW5-012 motherboard gets hot ...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@himo if it only gets hot on battery I'd start off with a replacement of the battery. Re-evaluate after that and if it continues you are most likely having a shortcircuit on the boards charging circuit. For further help we would need to have the exact model number of your motherboard, not your computer. It is possible that schematics are available for further troubleshooting.
Esta resposta foi útil?
Pontuação 2
I am having problem with my switch 10. It does not turn on but has an orange light on when the charger is plugged in. Also the motherboard gets hot. I opened the chasis and saw two wires were disconnected. Can anyone suggest a way such that the wires can be connected
Pontuação 0
Adicionar a sua resposta
Abraham será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Ao todo: 529
