New digitizer not functioning?
Had a particularly frustrating screen replacement yesterday with a digitizer screen that fracture and splintered with every successive pry. Finally managed to get everything apart and cleaned up with no further damage to internal components (VERY surprised that the instructions did not specifically call out disconnecting the battery BTW). Reassembled everything and went to test prior to sealing the new screen down only to find that it's not functioning. The home button works fine and the LCD has crystal clear picture, but there's no touch input whatsoever. Any chance we got a bad digitizer? Recommendations?
Esta é uma boa pergunta?
1 comentário
Final follow-up on this. The original digitizer was sent back before I could retest it, but I had the exact same issue on the replacement. I found that the white lines on the digitizer cable need to be inserted further into the connector (until they disappear into the connector). Unlike the LCD screen connector where the lines are still showing.
por Eric Montgomery Compartilhar
