Ir para o conteúdo principal
O primeiro modelo da linha de computadores pessoais da Apple. O iMac G3 foi produzido entre 1998 e 2003.
Glow or light up
I've been given an iMac G3 which is almost perfect. I've put OS 9.2.3 on it which runs fine.
The only problem is the blue shell does not light up or glow?
Searching the Web I came across a statement that there was a bulb somewhere near the round plastic handle but I can't see one.
Anyone know how to get it glowing again please?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Thanks for your help - I must have believed some hype Apple Advert I saw in 1998!
por
Adicionar um comentário
1 resposta
Solução escolhida
Hello,
I was looking up teardown of this particular model and I can't see anywhere the above mentioned light.
If you can provide me the link where you found that it was glowing at some point there is always a way to fix by the way could be steep because of the age of the machine.
You can look up how hard it's even to open this thing up:
https://www.youtube.com/watch?v=j-w-3LZi...
Esta resposta foi útil?
Pontuação 3
8 comentários:
That's modding, the MAC didn't have that built in.
por
You can send the MAC to experienced electrician/computer scientist if you want that the light is powered from inside from the computer. If you want to do it yourself without knowledge for computer science and electricity you can drill(somehow make) the hole and push the led strip inside powering it from outside with a cable.
por
If this answered you'r question please rate it and mark it solved so others looking for this subject know what's going on. Thank you.
por
I thought they were sold in a range of different colours and lit or glowed from new not that they had to be modified?
por
Exibir mais 3 comentários
Adicionar a sua resposta
Denny Tuckerman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 717
