Ir para o conteúdo principal
Lançado em 2012, identificado pelo número do modelo: R630020
Wont run, stops immediately
My Roomba stops immediately and plays the 4 note tune. It doesn't say anything. It goes "da da da do", where the last note is the lowest. No voice error. Does this mean a dead battery? My battery is 3 years old. The best I can tell it flashes one quick flash, then 6 slower ones.
UPDATE: It was the battery. I replaced the battery and off it went.
Thanks,
Brian
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
It was the battery. I added as an answer so that it's marked as resolved.
Esta resposta foi útil?
Pontuação 1
So your issue is fixed? Be sure to answer the question and mark it as solved! Thanks!
Pontuação 0
Adicionar a sua resposta
Brian Kowald será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 12
Ao todo: 592
