Ir para o conteúdo principal
The Nextbook Ares 8A is an Android tablet released March 2017.
Next book Ares8A when turned on says Android boot failed
Tablet is brand new. I turned it on and all I see is Android boot failed.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
worst tablet ever made.
por
Adicionar um comentário
1 resposta
Solução escolhida
Try a" wipe cache partition" this will allow a clean boot thisvideo showshow to do a factory reset but we want to do a wipe cache so instead of selecting the factory reset as he does in the video select wipe cache and carry on from there . This should help but it you find no joy then you will need to do the factory reset as in the video but be advised you will lose all your data . and apps and it will be the same as when you first got it . When you do a wipe cache you lose nothing . Hope this helps
Esta resposta foi útil?
Pontuação 5
6 comentários:
Hi @jimfixer ,
The video link is missing ;-)
por
sorry folks missed that, nice catch @jayeff
por
Doesn't help. The Android boot failure message occurs immediately and doesn't let you get far enough to do ANYTHING in your video.
por
I'm having the same issue.
por
It dosent help!!!!!!!!!!!!! It says the same thing Android boot failure
por
Exibir mais 1 comentário
Adicionar a sua resposta
Vickie Swisher será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 6,624
