My GoPro will not charge/turn on?
I have tried 2 different batteries, a new usb cable and it will not turn on at all.
Esta é uma boa pergunta?
@cperetin check the charging port to make sure it is not corroded, has any broken or bend pins or is otherwise damaged. If that does not work you will need to have to take it apart and check the connection of the port to the board. Use these guides GoPro Hero4 Silver to work on your GoPro
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 868
