Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Perguntas Visualizar todos
solder old nand flash on new motherboard
Hi,
My samsung galax s6 took water damage, but I want to retrieve the data on it. I already tried to replace the battery and usb connector unit. Both didn't work.
My last resort would be to buy a cheap 32GB mortherboard on aliexpress. And remove the 128GB nand flash from the broken phone and solder it on the 32GB motherboard.
1. Will this work in theory?
2. Can this job be done by someone with next to none soldering experience? btw, I dont care if i will screw up, because I see it as the last resort anyway.
3. Or do you have other suggestions to get the data back, which are not expensive.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Is there any way to fix the water damage?
Electronics Water Damage
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks, I already cleaned en submerged the boards with isopropyl alcohol. I couldnt really reach the processor, nand unit etc. though, since they are under a protective shell.
por
did you already try this? I'm in the same boat. I will try this today a let you know what happens
Pontuação 0
1 comentário:
Did you have any luck with this?
por
Adicionar a sua resposta
Mar Do será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 376
