TX-42ASX659 not turning on properly
Hey,
I asked this question before, but with the device "Televison". Idk why but you can't choose Panasonic Viera from the devices when changing it or opening a thread without any device selected in the first place. I didn't really get any help there so I figured I'd ask here since I made some progress and this is the right category.
My Panasonic TX-42ASX659 is not turning on properly.
As seen in this video, when turning on first the green light flashes then the screen turns on twice for a split second and then the light starts to flash once every three seconds.
I can't make out any pattern and I counted up to 30 until I gave up, so I assume it's error code one.
I tried every "reset" method I found on the internet.
- Holding down power button for 60 seconds with now power
- Holding down power button for 30 seconds with power
- Holding down power button and volume up/down for several seconds
I opened up the TV and checked for any blown capacitors etc. I'm not an expert, but everything looked ok, nothing out of the order. Here is a Imgur Album with some pictures of the insides.
I didn't really know what contacts to check so I checked all contacts labeled SRV - ?.? V. Those seem to be okay as long as the TV is on (Green light flashing), but some won't have any mensurable voltage when the red light blinks.
Like I said, at this point I am at my wit's end. I don't really know what to look for and what to check.
Thanks in advance!
Jonas
Update (01/11/2018)
Update:
I replaced the PSU, but sadly it doesn't work with this one either.
I checked the same TPs @oldturkey03 gave me in his comment and they have the correct value, so the new PSU itself seems to be working.
The error behavior is exactly the same as explained in the original post. Check out this Video
Esta é uma boa pergunta?
