Random Reboots even when Idle & screen turned off, panic-full in logs.
Hello,
I have an iPhone 7 currently on 10.3.3.
I have encountered 4 random reboots to date, the first happened about two months ago, the phone was laying on my desk when suddenly screen turned on and rebooted.
Second time was two weeks ago when I woke up and found it requiring by passcode because of a restart.
Third time and fourth time was yesterday and today respectively, one when I was holding the phone and I was on the homescreen, and the other the phone was laying down my desk with screen off.
In the Analytics there is a panic-full log for each restart, so it's clearly a kernel panic. I can't interpret the kernel panic log and I wish someone here may be able to understand it and points out where may the error be.
It is worth mentioning that the phone performance, temperature, and battery life is perfectly normal.
I currently have the 3 recent panic logs:
First panic-log: pastebin.com/C9uts03A
Second panic-log: pastebin.com/tNmsbFM4
Third panic-log: pastebin.com/SsKegDLb
TL;DR
-Phone randomly rebooted four times to date even when I'm not using it and screen turned off, panic full logs found in logs, I'm trying to figure out from the logs what maybe wrong with the phone.
Esta é uma boa pergunta?
2 comentários
I cannot personally tell you why the kernel panics are occurring, but is there a reason you just haven't upgraded to ios 11 via iTunes? That will probably solve your issues, or I would just backup your data and do a factory reset.
por Michael Stefanchik
I don't want to upgrade to iOS 11 as much as possible, iOS 11 is half-baked imo and introduces more hassles that it solves. I can't see why would iOS 10 be the problem ? iPhone 7(s) have been shipping with iOS 10 for an entire year and it should be stable. I've done a full data reset today and I'll monitor if kernel panics occur again. I might upgrade to 11 if it happened again as a last solution before sending it to another country to repair or replace it under warranty.
por sherifabdlnaby
