N64 no signal with AV cable
Hi all,
N64 is giving me a no signal message on my Samsung TV.
The power red light is on.
The same AV cable works on the GameCube.
I've tried removing Expansion Pack and different cartridges.
The console has worked in the past years (not played in the past 3)
Should I buy a SCART adaptor?
What else can I do to make it work?
Update (12/31/2017)
Fixed it, maybe. I extracted the Expansion Pack again, inserted the old pack, then inserted the Expansion Pack once more and it works.
Though now it does not detect controllers in port 1.
Esta é uma boa pergunta?
8 comentários
Hi @felmaloney ,
Sounds as though the contacts were dirty. try cleaning them with IPA 90%+
por jayeff
Thanks, @jayeff
I opened and cleaned the controllers with alcohol, but do you mean cleaning the part you plug in?
por Felix
I just had this issue, tried cleaning all contacts on console and games as well as re seating the expansion pak. Still the same fault; no signal.
What did fix it was slightly lifting the cartridge up after inserting it down fully, raising it up 3-5mm and it works perfectly!
Maybe all the gunked up dust at the bottom of the console cartridge port prevents a good connection(and is near impossible to access to clean).
Aztec level here we go!
por Chris Lowe
Hi I have a old Nintendo 64 and it a model number is NUS-001 it has a rating 19 and we Lost are av cable and we buy some on eBay but they don't fit because we see a little line of wire so where could we get on all those on eBay are plastic but us need metal on so please help us to get that thank you
por guylainec205
I have a Samsung smart tv and I got an av2hdmi adapter to get my N64 to work and all I get is the blue screen that says no signal. I've tried everything and cant seem to get it to work. What am I doing wrong?
por Billie
Exibir mais 3 comentários
