Ir para o conteúdo principal
Guias de reparo para câmeras alemãs da Leica.
The view finder on my Leica V-Lux 3 shattered when it fell. A fix?
The view finder on my Leica V-Lux shattered when it fell to the floor. the camera still shoots wonderfully, but I can only see a portion of my subject when shooting. Can the view finder be replaced?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Can you describe the damage a bit more here. Is the eyepiece broken? Is the top cover damaged? Is the viewfinders image distorted?
por
Adicionar um comentário
1 resposta
Solução escolhida
James Stewart the only way would be by checking where the damage has occured. Post some good images of what your viewfinder looks like etc. Use this guide Adicionar imagens a uma pergunta já existente for that. It will allow us to see what you see. Since you see your objects partially you will have to see if anything/what is obstructing the electronic view finder (possibly a dislodged filter etc.). The Leica V-Lux 3 is an almost exact clone of the Panasonic DMC-FZ150 It only has minor outside cosmetic difference but function etc. is the same. Service manuals for the Panasonic are widely available and should help you further.
Esta resposta foi útil?
Pontuação 3
3 comentários:
@oldturkey03 people care to much about the "Red dot" which is why they buy the leica. Pany and leica have a deal on some of Pany's cameras that I believe they still do.
Anyway, because the OP said the elements in the viewfinder shattered, I'm positive a replacement is necessary. I found this on eBay but I couldn't tell exactly tell if it's the optics too. It looks like just the viewfinder and diopter adjustment.
por
@pccheese I do agree with you wholeheartedly but do like to give the OP a chance to show us how/what is broken. The replacement you found should work for the camera.
por
Not all of us, I pay more to have a Leica without the red dot, i.e. the P versions. I buy them for the optics and build quality. Leica cameras and lenses that have a Panasonic equivalent are all made by Panasonic in Japan, so that is a very good reason to buy the Panasonic, you won't be getting the Leica build quality anyway, so why pay more?
por
Adicionar a sua resposta
James Stewart será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 20
Últimos 30 dias: 46
Ao todo: 832
