Ir para o conteúdo principal
O SwagTron T3, lançado em 2016, é um hoverboard de autoequilíbrio que possui indicadores luminosos de movimento, alto-falantes Bluetooth, uma alça de transporte integrada e um indicador de bateria de 5 níveis.
Can I replace my cracked SWAGTRON T3 shell?
Can I purchase a new shell for the SWAGTRON T3 ?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Did you buy it at Target? Black Friday? We bought 3 - two were cracked upon opening the box - both right at the join between the footplate and the fender. The third board cracked and broke in that same location within the hour. I contacted Swagtron right away (they were actually open on Christmas) and worked through the issues with them. It was time consuming to document everything on my end, but it made the process much easier. One of the associates confirmed that they had a large number of calls coming in about the same problem - at that same location on the board.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Who do I contact as I had the same issue within hours of my son using it.
Pontuação 1
1 comentário:
Contact Swagtron via the Chat option on their website or call them directly. They repaired all three boards for us as no cost. They were very helpful. I hope that the same happens for you.
por
I have had the same issue contacted SWAGTRON and they said it was cosmetic so they won’t do anything.
Pontuação 0
1 comentário:
Was it a chip, a crack or a break? Contact Swagtron via the Chat option on their website or call them directly. You can always ask to escalate it to a manager. Send them pictures, etc.
por
Adicionar a sua resposta
Shelly será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 1,223
