Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
Esta é uma boa pergunta?
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
Esta resposta foi útil?
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
Yes I checked the door and it made contact but I was never able to get the camera working
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,004
2 comentários
I’m having the same issue with my s95. Battery door compartment is all fine but still won’t turn on. Has anyone found a solution please help a girl out :(
por Christina
@christina73227 does your S95 give you any sign of life? Checked the battery, just to make sure?
por oldturkey03
