Can not find disk
Can I recover my pictures and folder?
Esta é uma boa pergunta?
Allen if the hard drive hasnt failed and its only a boot sector problem you can remove the hard drive or ssd from the computer and put it in an external enclosure and recover your files this way but if the hard drive has failed then you will need more experienced help from a data recovery firm
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 14
Ao todo: 104
1 comentário
Hi,
Annoying first question to ask I know but have you made a backup copy of your pictures recently?
Have you proved whether the problem is with the HDD or the PC?
If the problem is with the HDD then you may have to contact a professional data recovery service and see if they can manage it.
por jayeff
