Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Could an iPhone 6s screen be transferred onto an iPhone 7?
So I have a broken iPhone 7 screen and I have a iPhone 6s. Seeing that the dimensions and the display specs are very similar I am curious if it is possible if I could save money by just switching the screens. I want to know if this is possible in the first place before I go through the trouble of finding out how to go about doing it.
Esta é uma boa pergunta?
Pontuação 1
4 comentários
I broke my iphone 6s screen and out of curiosity I put an iphone 7 screen onto the iphone 6s and holly by hold it certainly did fit,my phone is as good as gold
por
Have you had any problems since then? Is there anything to consider if I build the display of my iphone 7 into my iphone 6s?
por
Wait how is that possible
por
I I am assuming you are talking about the outer glass only
por
Adicionar um comentário
2 respostas
Solução escolhida
Nope.
Esta resposta foi útil?
Pontuação 4
3 comentários:
I second that.
por
Do you know why?
por
Because it won't fit and it won't plug in and it will stay on apple logo boot loop if it plugs in.
por
first issue is that the connectors will not connect to eachother.
however, even if you have the ability to manually jump each pin, the PLDs on the motherboard will not support the Logic Circuits of the 6S. You will unfortunately need to purchase an iphone 7 LCD assembly.
Pontuação 0
Adicionar a sua resposta
Khannuuuuur será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 33
Últimos 30 dias: 149
Duração total: 33,813
