Ir para o conteúdo principal
Repair information and guides for the updated version of the 2015 Retina MacBook that was released in early 2016. Model A1534 / EMC 2991
140 Perguntas Visualizar todos
Has anyone successfully replaced a battery for this?
Anyone ever attempted a battery replacement on this? I know iFixit says there’s super strong adhesive but if it’s similar to the strong adhesive on the iPhone battery, then it just seems like the same process but 5 times.
Mine is wearing out and sitting at 85-89% with about 280 cycles. I feel like the degradation is going pretty fast... (and yes, I will bring it to Genius Bar later if I can't do the fix myself).
Esta é uma boa pergunta?
Pontuação 2
3 comentários
That would be a pretty good guide @sam (I would do it myself but can't because I don't have any)
por
I guess I should amend my question: I see you all sell the MacBook 2015 battery replacement but there's no 2016 replacement. Your 2016 teardown suggests that the battery is compatible but the 2016 model battery may be larger slightly. Any chance you'll have those in stock?
por
Any thoughts on this @sam, now that the holidays are over? :) Coconut battery is reporting that my battery is degrading at a precipitous rate (82.9% atm and was at 87-89 when I wrote this initial post)
por
Adicionar um comentário
1 resposta
Solução escolhida
I have successfully done a repair of this battery, although I do not reccomend this to anyone that has little to no repair experience. If you are willing to do this and are skilled enough to, my advice would be just take your sweet time with the battery. It is flimsy and damaged easily so just be extra careful while doing this replacement. Lord Adhesive really put up a fight for this replacement!
iFixit Replacement Guide
MacBook Battery
Imagem de MacBook 12" Retina (Early 2016-2017) Battery
Produto
$109.99
Esta resposta foi útil?
Pontuação 3
2 comentários:
@oldturkey03 Wow, did I get carried away... taking down all the upvotes now :o
por
And no, the points really aren’t a big deal anyways. The only thing that counts is happy, satisfied users :)
por
Adicionar a sua resposta
Chris será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 649
