Ir para o conteúdo principal
Lançado pela Samsung em março de 2016. Modelo SM-G930, Versões: G930F (Global); G930FD (Global; Sudeste Asiático); G930W8 (Canadá).
Finding IMEI with FRP lock
hey guys.
Im looking to get the IMEI off of a board i got delivered. but its FRP locked. there are no identifiers on the board itself, and the dial code *#06# doesnt work because emergency caller wont allow it.
Am i missing something as to where that should be recorded? i know iphones have the "i" at the bottom corner, but samsung doesnt appear to have it.
Esta é uma boa pergunta?
Pontuação 10
1 comentário
this is lwky a good question, I have the same problem, my best friend gave me her old Samsung Galaxy s7, and she kinda just gave me the password and got tfo so I looked up a ton of shi and the FRP lock is genuinely killing my soul right nowwwww.
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Does Download mode or Recovery mode show the IMEI?
Download Mode may show through adb?
Esta resposta foi útil?
Pontuação 3
7 comentários:
neither of them show the imei. Im currently installing ADB to run through the last suggestion. while im doing that, do you have the command i would use to pull the IMEI through adb?
por
adb shell dumpsys iphonesubinfo
por
i get No device/Emulator found When i try to connect. i Have Google USB drivers installed in my SDK manager.
por
Removed comment.
por
Exibir mais 2 comentários
press volume up, power and home buttons all at same time. While holding down all 3 buttons the screen will start to flash and immediately let up on buttons and hit volume down and the IMEI, SKU and SN will appear on the screen.
Pontuação 1
1 comentário:
Should the phone be off or on ?
por
if the battery cover is original it will have the imei at the bottom, hard to see i suggest some kind of led light to shine against it
Pontuação 0
Adicionar a sua resposta
Scott será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 12,955
