Ir para o conteúdo principal
The Apple Xserve server, the Xserve Xeon Nahalem server, is an Intel based computer server released on April 7th, 2009.
6 Perguntas Visualizar todos
OSX Upgrade on 2006 xserve
I have an xserve 2006 (emc2107) running MacOSX 10.7.2 Lion Server. I read that it can be upgraded to 10.7.5. I burned a copy of 10.7.5 client upgrade and 10.7.5 server upgrade. Here is the good part, I mislabled the disks. So I used 10.7.5 client upgrade on the xserve running 10.7.2 Server. Is there a way to recover my server os? I hope that just installing the 10.7.5 Server upgrade will work but I don't wanna make things worse. Basically if anyone can give me some advice I would greatly appreciate it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Does anything show up in the software update app?
Do you still have server.app? If so, try just opening it.
Starting with OS X 10.7, there is not really a "Server OS", the server software is simply added to the normal Lion OS, so you should be fine.
Also, in "About this mac", what is listed as the software?
Esta resposta foi útil?
Pontuação 0
1 comentário:
I will check that out tomorrow morning and get that information to you.
por
Adicionar a sua resposta
Pete será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 298
