Broke off tip of knife
I have broken off the tip of my kyocera knife
Can it be fixed
Esta é uma boa pergunta?
Can it be fixed
Sure you can. You will need an electric sharpener. Here's a video on how to do it:
Esta resposta foi útil?
I'm not sure if you can fix a knife. Especially the tip, the knives are too thin to use crazy glue or something like that and I'm not even sure if it would be safe to put crazy glue on something you eat with. You also can't use it's not strong enough.
No - there isn't any way to re-bond the ceramic material, especially in the tiny surface area of the fracture. Continue to use if you can or -sadly- discard and replace it.
Últimas 24 horas: 8
Últimos 7 dias: 13
Últimos 30 dias: 28
Duração total: 1,481
