Ir para o conteúdo principal
Released in 2013, the Asus X550C is a line of budget Windows 8 ultrabooks. Related model numbers: X550CA, X550CC, and X550CL.
17 Perguntas Visualizar todos
Why does my laptop bring up a black screen
My laptop will bring up the Asus logo and then the screen turns black and will stay like it for hours.
I’ve pressed f9 when the logo comes up to reset it and all it tells me is the laptop needs a disc ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@mollieclarke09 connect an external monitor and see if it does the same thing. It is possible that your computer is unsuccessfully trying to access the OS. If you stay in your computers BIOS will it stay on? If so then it is most likely an OS (possibly HDD) issue. Try to see your startup sequence to USB or optical drive and get a bootable CD/USB drive to determine if that works.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Mollieclarke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 703
