Ir para o conteúdo principal
O Power Mac G5 é um computador desktop produzido pela primeira vez em 2003 pela Apple Corporation. Foi revisado três vezes antes de ser descontinuado em 2006 como parte da transição para processadores Intel. Números de modelo M9494, M9454, M9455, M9457, M9555, M9747, M9748 e M9749.
Unique Not powering On Issue?
Good day!
I recently bought an old G5 Powermac Dual 2.0Ghz along with a 23" Cinema Display. Model is an A1047, EMC 1969, PowerMac 7,2, made June 2003-June 2004; all based on the Serial lookup on everymac:
https://everymac.com/systems/apple/power...
Aftermarket ad-ons, which were already installed:
  • There is an aftermarket ATI Radeon 9800Pro 256mb Graphics Card installed. The GPU fan does spin.
  • There is 1.5GB of RAM (6x256MB).
  • It did NOT come with a hard drive, but I do have 2 working hard drives which I installed to see if I could get it to boot. One with 10.5, and one with 10.0 (although, I realize that everymac says 10.2 is the lowest it came with).
I have done research and haven't been able to find anything based on my specific problem(s):
  • First, and this is the weirdest based on not being able to find anything about it….when power it on the LED light turned on as the button is press; however, as soon as I remove my finger the LED turns off - yet the machine is still running. Anytime after removing my finger from the power button (meaning that the LED is off while the machine is on) if I press the button the light will turn on, and as soon as I remove my finger from the button the LED power light turns right back off (but not the machine).
  • There is NO chime.
  • The fans ARE running.
  • If I leave it running for about 1-2 mins the funs begin to spin very fast…it sounds like an aircraft! lol
  • There is NO display to the, Cinema display, which DOES work as tested through the ADC to DVI adapter to my other Mac.
  • Various, and working, USB keyboards and mice do not work. Caps lock will not light up, and the mice have no optical lighting underneath. Also, the eject button on the keyboard doesn't do anything.
What I have tried, based on other articles:
  • Power supply does click when plugged in, read in the Apple manual that good ones often do that.
  • Swapping the positions of the CPUs.
  • Running only 1 CPU on the #1 (top) CPU slot; tried with both CPUs.
  • Reseating the RAM.
  • Using different combinations of the RAM (however using the same amounts, same locations on both sides).
  • Removing the graphics card to see if the boot up chime will happen (read that can be a way to test if it is bad, when you don’t have an extra GC laying around).
  • I was able to use a paperclip to open the DVD drive, and it does closed by itself when you push the tray.
  • Replaced the PRAM battery.
  • Tried resetting the SMU by pressing the SMU reset button on the logic board.
  • Ensured the CPUs were seated correctly.
  • Capacitors look good
Note, that in all of the various combinations mentioned, the power LED light does not stay on unless the power button itself is being pressed.
What are some of your thoughts here? I feel that testing the logic board and individual CPUs with ones known to work would be the next best approach; however, before going out and buying anything I thought I would see what others thought!
Hopefully, this can help someone else too!
Thank you for any help you may provide! :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Locate and press the CUDA button on the logic board and let me know if anything changes. https://support.apple.com/en-us/HT1436
Remove the 10.0 drive for now. It's best to try to take a machine back to the original configuration when diagnosing. Replace the PRAM battery.
Substituição da bateria PRAM do Power Mac G5
UPDATE
here's where to go next:
Here's what Apple will tell you on the 7 LEDs: http://support.apple.com/kb/HT2652
Now here's where to find what they really mean:
Page 139 of the Service Source Manual
Power Mac G5 (Late 2005) Troubleshooting — General Information14 0 Diagnostic LED Table LE
http://www.scribd.com/doc/21536787/Apple...
Esta resposta foi útil?
Pontuação 2
6 comentários:
Thank you very much for your help, Mayer! I have seen several of your posts on other topics before I created this account (which I did today), and wanted to say thank you for those as well!! :)
* I just tried the CUDA button (again) with no avail. It is still turning on, while at the same time no chime, no video, no USB interfaces, and the LED at the power button is OFF (while the machine is ON), fan still spin slow for the first couple of minutes before Sulu sends them to warp!
* I did remove the 10.0 hard drive as well.
* I also just tested the PRAM battery (which was just replaced), and it measures at 3.6V.
Would you happen to have any other ideas/suggestions??
por Compartilhar
Thank you for the update!! That is a great manual!
I was looking through the manual and found some ideas that are very close, staring on page 144 "System Failures".
The closet one I have found is, "Power-on LED illuminates when pressed in, but goes out when button is released,there is no boot tone or video, but you can hear a small click"; however, there is no *click* occurring, as the system and fans are turning on.
I am thinking that I will go through the various ideas under "System Failures" like trying a new video card, new front panel board, then processors, logic board...maybe I'll get lucky and it will be something simple!
What are you thoughts?
And, thank you again for everything!! :)
por Compartilhar
The two things (in order) that I have seen fail on this model the most are, the video card, the PSU.
This is the card I use most to replace with:
GeForce GT 120
por Compartilhar
Thank you very much! It will be a few weeks before I can buy a replacement video card. After I do I will let you know how it goes! :)
por Compartilhar
@efitz Do a new PRAM battery first. It's a 1/2 AA 3.6 volt. You should be able to get one for about $6.00
por Compartilhar
Exibir mais 1 comentário
Try and reset the pram battery command+option+P+R
Pontuação 0
1 comentário:
no , no power to usb devices (keyboard does not work )
por Compartilhar
your Motherboard has failed , buy another one or have it repaired . i have the very same board with exactly same symptoms ,repairs without schematics or diagnostic procedures in my case may not be possible (attempting)
Pontuação 0
Adicionar a sua resposta
Edward será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 2,698
