Where is the camshaft positioning sensor located 1.8L
hi, can someone let me know where this is? 2011 Elantra 1.8L
thank you
Esta é uma boa pergunta?
thank you
It is in the front of the engine, down low, just to the right (as you are facing the car from the front) of the oil filter.
Esta resposta foi útil?
This is erroneous! This is the location for the crank sensor.
No it's not that the crank sensor can sensor is on top of motor.
@rnps old question and just to clarify. The camshaft position sensor is (are since we do not know if this is a 1.8L DOHC engine which would have two) located under a cover on the TOP right of the engine.
image credit goes here
Hopefully you got this fixed within the last 4 years :-)
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 75
Duração total: 4,048
