apple hi-fi won't work on mains, it only works on batteries.
Hi, my apple hi-fi won't work on mains supply, it only works on batteries. help
Esta é uma boa pergunta?
Hi @iain_sinclair ,
You will have to open the device and then check the connections from the mains power inlet to the motherboard.
Here is a link that hopefully may be of some help.
If you cannot see (or test, using a DMM- digital multimeter) what the problem is, take some close up pictures of the motherboard and perhaps someone will be able to help you further. Here's how to do that. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 250
7 comentários
Please explain. Do you mean it won't work on wall power?
por Reed Crosby
yes, thats correct it won't work on wall power
por Iain Sinclair
Have you tried a different outlet?
por Aiden
yes tried different wall outlets and different power lead, the problem is with the apple unit.
por Iain Sinclair
did you drop it before? anything happen before it broke?
por Aiden
Exibir mais 2 comentários
