Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Searching for Transistor chips
Hello Guys.
I was able to change my CPU on this board but one stupid thing was happen:
I cant lift up the CPU with my mini Vakuum Sucker.
So there fell apart some pieces and now i need to replace the (TSP)51619 which controlls the Power of the DDR3L Memory. but byside of this are some tiny black
"Transistors"?
And there is no Water on the Board. it is only Pattex Glue to save the other componets from falling appart.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Klaus Iwik these components are not transistors. Those are all resistors.
Reference designator R7611 is a 35.7K ohm 1/20W 1% resistor in a 201 package
Reference designator R7614 is a 14.7K ohm 1/20W 1% resistor in a 201 package
Reference designator R7613 is a 47.5K ohm 1/20W 1% resistor in a 201 package
Reference designator R7613 is a 100 ohm 1/20W 5% resistor in a 201 package
Esta resposta foi útil?
Pontuação 1
2 comentários:
Very nice =)
Now i need to find a reseller of these.
por
@luckylastone depends on where you are located. I get mine from Mouser.com Digikey.com as well as multiple other common sources. Just checked Mouser and they do carry all of them. Careful so, shipping is expensive ;-)
por
replace the logic board and the path CPU on the new one
Pontuação 0
1 comentário:
I just byed a old damaged board with Parts on it which i needed for 22Bucks =)
Thanks for this great idea!
por
Never finished this board because I found a used one for 200bucks that is now working in my Book =)
Pontuação 0
Adicionar a sua resposta
Klaus Iwik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 248
