Ir para o conteúdo principal
Dancing water speakers are computer speakers that feature jets of water illuminated by bright multi-color LED lights.
9 Perguntas Visualizar todos
Sound works fine, water won’t shoot up.
I bought a Sylvania water dancing speaker a while ago. Sometimes i have the tendency to leave my speaker on while i run a quick errand. I once left it on, thinking i wouldn’t take long — i was wrong. It stayed powered on several hours without any music playing, so when i got back i noticed the water wasn’t shooting up. Usually all i had to do was power off, & power back on to get the water to work fine again. This time it didn’t, the sound works fine. It lights up, but no water goes up.. Yet it’s still got water in it. Same amount as when i bought it. Can i easily fix this at home? Thanks!
Esta é uma boa pergunta?
Pontuação 2
3 comentários
What my water not coming up wen i play music
por
Have soundproof dancing water tower speaker, sounds good but the water doesn't shoot out to the music what is wrong?
por
Help how do i take it apart.to refill water
por
Adicionar um comentário
3 respostas
Solução escolhida
Open it up and use a multimeter to test for continuity of the wiring and see if you may have burned the motor out. Here's how to do surgery on it:
Water Dancing Speakers Refill
Esta resposta foi útil?
Pontuação 6
Pergunta mais útil
I bought a Sound Logic Wireless Dancing Water Tower Speaker and i noticed the water didn't shoot up anymore what can I do to fix it at home?
Pontuação 8
2 comentários:
I have the sameone and the water stopped shooting up. Did you ever figure out what was wrong
por
same here so I took it apart and everything was naked just fine the motor was no longer turning so now I'm trying to find where I might order a new little motor which is really quite easy to wire into place , just two little sodering spots to connect it but i just started looking for the part
por
My soundlogic BTS-600 won't stay on what's wrong with it I have to hold button for it to stay on
Pontuação 0
Adicionar a sua resposta
Marely será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 22
Últimos 30 dias: 90
Duração total: 10,552
