Ir para o conteúdo principal
Ferro de passar roupas Shark Ultimate Professional de 1800 watts, identificado pelo número de modelo GI505.
Iron not powering on
My Iron is plugged in and is still not powering on or heating up, could the cord be broken?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Pergunta mais útil
Have you tried a different plug? Or maybe the iron needs more water.
Esta resposta foi útil?
Pontuação 3
Open it up using this guide and then use a multimeter to test it:
Substituição da placa de circuito do Shark Ultimate Professional
Pontuação 3
1 comentário:
Would you be willing to work on an iron?
por
This Happens sometime, If you forgot to switch off your iron it get over heated and may melt the wire of circuits of the iron.  I have gone through it, Do check your Wires properly. Also check the power wire fwether it get burned out or not.  You may need to replace whole wire.
In case you are planning to buy Get it here: - Best Steam Irons in market
Pontuação 2
1 comentário:
If you know someone who would be willing to work on an iron, I would like to mail it to them and pay for the service. Thank you, Stephanie
por
Adicionar a sua resposta
Matt Brunswick será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 50
Ao todo: 7,099
