Ir para o conteúdo principal
Battery operated RC truck designed for rock crawling and off-road terrain. Made by Maisto Tech.
17 Perguntas Visualizar todos
Can the truck be tested or powered on without a remote?
We bought a used truck at a thrift store, and it didn't include a remote. Before we invest in a replacement of the remote, we'd like to test the actual truck to make sure it works. Is there any way to test the vehicle without a remote, such as turn on the motor?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Yeah, you could theoretically wire up some batteries to the motor if you can access the main circuit board and see in it does anything. While I don't own this this thing personally and never tried this, I don't see what could go wrong. Just be sure to wire the batteries/ power source up properly and avoid applying too much power.
PS: This will also be helpful.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
EJ M será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 112
