Ir para o conteúdo principal
Maisto Rock Crawler Truck Circuit Board Replacement
O que você precisa
  1. Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: passo 1, imagem 1 %32 Maisto Rock Crawler Truck Circuit Board Replacement, Truck Circuit Board: passo 1, imagem 2 %32
    • Flip the R/C truck over.
    • To take off the R/C truck top, use the driver and bit PH2 and remove the four 7.7mm Philips screws highlighted.
  2. Maisto Rock Crawler Truck Circuit Board Replacement: passo 2, imagem 1 %32 Maisto Rock Crawler Truck Circuit Board Replacement: passo 2, imagem 2 %32
    • Half way remove the truck top so you can unhinge the antenna from the clips.
    • Remove the R/C truck top completely.
  3. Maisto Rock Crawler Truck Circuit Board Replacement: passo 3, imagem 1 %32
    • Use the Driver and bit J1 to remove the top under-body plate by unscrewing the eight 9.5mm Philips screws.
  4. Maisto Rock Crawler Truck Circuit Board Replacement: passo 4, imagem 1 %32
    • Use the driver and bit J1 and remove the 7.7mm Philips screw highlighted.
  5. Maisto Rock Crawler Truck Circuit Board Replacement: passo 5, imagem 1 %32
    • Take note of which wire is connected at which pin before desoldering. It might help to mark the wires and take a picture.
    • It would be easier to desolder and resolder only one component at a time.
    • Use the soldering iron to desolder all the wires connected to the circuit board.
Conclusão
3 outras pessoas executaram este guia.
kevin
Membro desde: 02/10/16
874 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 1-2, Sullivan Spring 2016 Membro de USF Tampa, Team 1-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G2
Membros da 3
Autoria de 6 guias
9 comentários
Can you do anything to it to make it stronger are powerful
Matt John - Responder
Yes put a board from a nikko or ez tec in it. The 9.6 volt is the one to find and wire the motors to the single motor output. I think u have to wire one backwards to get both going right way
Mike - Responder
My rc car is not responding to left or right signals from remote.
CAN I got any help on this
pankaj kapatia - Responder
Can any one help as my rc rock crawler is not turning left or right
did you use biger voltage than normal? because it sound like that. i think your’s car has brokened ic-component.
mattilajanne - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 41
Duração total: 5,527
