Ir para o conteúdo principal
Broke the lightning connector - parts stuck in logicboard
Hi.
My phone won't charge. I replaced the battery and the phone lasted for some time (20% remaining on new battery). Then I bought a new dock connector to try. The problem is that when I disconnected this, half of it got stuck in the connector.
Is this repairable? I have not been able to pull the parts out with my 0,8mm flat screwdriver.
Any advice and help is much appreciated!
Se link for pictures of the contact.
Thank you
https://imgur.com/a/Nyzkh
Esta é uma boa pergunta?
Pontuação 0
3 comentários
try a set of fine point tweezers
por
Bought some tweezers. Didn't help and I guess it's getting more and more damaged now...
Will this repair be comparable that of the Tristar replacement then? Maybe a repair shop that does microsoldering can do them both(?)
Thank you for your reply, daniel.
por
you will just need someone that can microsolder to remove the old connector and solder on a new 1
por
Adicionar um comentário
1 resposta
Solução escolhida
It seems like corrosion made those connectors stick. You have to replace that connector and inspect around logic board to make sure there is no more damage on the logic board. If you are not a micro solderer id recommend finding a shop who can help!
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Bjørnar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 110
