Ir para o conteúdo principal
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Perguntas Visualizar todos
MacBook gets really hot and fan is Really loud
Hi,
I have a late 2006 MacBook and I've noticed that the fan gets really loud and it gets REALLY HOT! I've had the machine for about a year and don't know any information on it before it came into my hands.
What steps can I try to try and reduce the heat from the CPU?
I'm thinking on replacing the thermal paste on the machine as it most likely has over 10 years since it has seen new thermal paste.
P.S. I'm running MacOS Yosemite and all my apps are up to date.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
You may want to get a good thermal sensor & fan monitoring app like this one: TG Pro it will allow you to see more clearly want is getting hot and if the heatsink or fan needs attention. Post a screenshot of the main screen so we can see whats up too.
por
Adicionar um comentário
2 respostas
Solução escolhida
Sounds to me like the heat sink is not doing it's job. Some for these are liquid filled. Examine the tip where the crimp is and look for an oily looking residue. If you find it, replace the heat sink: MacBook Core 2 Duo Heat Sink Replacement
Esta resposta foi útil?
Pontuação 1
Have you removed the casing/chassis covers yet? You may want to make sure the fan/cpu is clear of dust and debri. Also check the ventilation for obstructions. Re-applying the thermal paste is the last step I would do after checking for these things.
Pontuação 0
1 comentário:
I have confirmed that they are clean.
por
Adicionar a sua resposta
Dudefoxlive será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,310
