Manuel transmission 1999 Saturn sl, replace
5 speed Manuel trans replacement
Esta é uma boa pergunta?
William Emerson excellent write up about the how-to on here. Definitely not an easy job. I would also recommend that if you need more information on this extensive task, visit your local library and see if they have the manual.
Esta resposta foi útil?
Thank you for your help, I have a 1999 3 door Saturn 5speed Manuel trans, mine is broken looking for another one
William Emerson not sure where you are located. I would connect with a local recycler. I guess that's what they call the wrecking yards now. Even if they do not have it they can probably find one for you.
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 77
